1240
Exception when setting the Theme
On occasion, when I set the theme in code behind, I get an exception with the message "The calling thread cannot access this object because a different thread owns it."
Here is the call stack:
   at System.Windows.Threading.Dispatcher.VerifyAccess()
   at System.Windows.Threading.DispatcherObject.VerifyAccess()
   at System.Windows.Style.CheckTargetType(Object element)
   at System.Windows.StyleHelper.UpdateStyleCache(FrameworkElement fe, FrameworkContentElement fce, Style oldStyle, Style newStyle, Style& styleCache)
   at System.Windows.FrameworkElement.OnStyleChanged(DependencyObject d, DependencyPropertyChangedEventArgs e)
   at System.Windows.DependencyObject.OnPropertyChanged(DependencyPropertyChangedEventArgs e)
   at System.Windows.FrameworkElement.OnPropertyChanged(DependencyPropertyChangedEventArgs e)
   at System.Windows.DependencyObject.NotifyPropertyChange(DependencyPropertyChangedEventArgs args)
   at System.Windows.DependencyObject.UpdateEffectiveValue(EntryIndex entryIndex, DependencyProperty dp, PropertyMetadata metadata, EffectiveValueEntry oldEntry, EffectiveValueEntry& newEntry, Boolean coerceWithDeferredReference, Boolean coerceWithCurrentValue, OperationType operationType)
   at System.Windows.DependencyObject.SetValueCommon(DependencyProperty dp, Object value, PropertyMetadata metadata, Boolean coerceWithDeferredReference, Boolean coerceWithCurrentValue, OperationType operationType, Boolean isInternal)
   at System.Windows.DependencyObject.SetValue(DependencyProperty dp, Object value)
   at Infragistics.Windows.DataPresenter.GroupByAreaFieldLabel.SetStyle(Style defaultStyle)
   at Infragistics.Windows.DataPresenter.GroupByArea.CreateGroupByAreaFieldLabelFromField(Field field, Style defaultStyle, Boolean forGroupedFieldsArea)
   at Infragistics.Windows.DataPresenter.GroupByArea.RefreshAvailableFieldLabels(FieldLayout fieldLayout, GroupByAreaFieldLabelCollection availableFieldLabels, Boolean notifyCollectionChanged)
   at Infragistics.Windows.DataPresenter.GroupByArea.OnThemeChanged(Object sender, RoutedPropertyChangedEventArgs`1 e)
   at System.Windows.RoutedPropertyChangedEventArgs`1.InvokeEventHandler(Delegate genericHandler, Object genericTarget)
   at System.Windows.RoutedEventArgs.InvokeHandler(Delegate handler, Object target)
   at System.Windows.RoutedEventHandlerInfo.InvokeHandler(Object target, RoutedEventArgs routedEventArgs)
   at System.Windows.EventRoute.InvokeHandlersImpl(Object source, RoutedEventArgs args, Boolean reRaised)
   at System.Windows.UIElement.RaiseEventImpl(DependencyObject sender, RoutedEventArgs args)
   at System.Windows.UIElement.RaiseEvent(RoutedEventArgs e)
   at Infragistics.Windows.DataPresenter.DataPresenterBase.RaiseEventHelper(RoutedEventArgs args)
   at Infragistics.Windows.DataPresenter.DataPresenterBase.OnThemeChanged(String previousValue, String currentValue)
   at Infragistics.Windows.DataPresenter.DataPresenterBase.OnThemeChanged(DependencyObject target, DependencyPropertyChangedEventArgs e)
   at System.Windows.PropertyChangedCallback.Invoke(DependencyObject d, DependencyPropertyChangedEventArgs e)
   at Infragistics.Windows.DataPresenter.DataPresenterBase.OnPropertyChanged(DependencyPropertyChangedEventArgs e)
   at Infragistics.Windows.DataPresenter.XamDataGrid.OnPropertyChanged(DependencyPropertyChangedEventArgs e)
   at Infragistics.Windows.DataPresenter.DataPresenterBase.set_Theme(String value)
It does not happen every time I set the theme, but since it’s deep inside of the data grid’s code, I can’t figure out the cause or solution.
Any ideas?
Dan
