365
Apply/Reset Filter in runtime
I'm using xamDataGrid to display some info. Each row has a boolean field named IsActive. My task to add a checkbox under the grid 'Hide inactive items' to allow user manage his information. If checkbox is checked I need to apply filter and if unchecked I need to reset it.
I've tried the following code in checkbox checkedchanged event handler but it doesn't work -
private void CheckBox_Checked(object sender, RoutedEventArgs e)
    var isChecked = ((CheckBox)sender).IsChecked == true;
    if (isChecked)
        var filter = new RecordFilter();
        filter.FieldName = "IS_ACTIVE";
        filter.Conditions.Add(new ComparisonCondition(ComparisonOperator.Equals, true));
        _grid.FieldLayouts[0].RecordFilters.Add(filter);
    else
        _grid.FieldLayouts[0].RecordFilters.Clear();
Could you please advise the best solution for my case?
