255
XamComboBox Value Converter when overriding the Item Data Template
Im trying to do very simple thing but facing an annoying issue:
basically I have XamComboEditor that I override its Item Data Template as simple text block so I can use a Converter with Text property binding that will display my item in certain format. When I run the app and drop down the list everything shows as expected. If I Select an Item from the drop down , the selected Item will show in the converted format as expected only if I set the ValueToDisplayConverter to the same converter used in the text block, which is fine. The problem Im facing is if I set a default value for the combobox selected item from the code behind and then run the app , the selected value will show as the string representation of my item type for example "wpfApplication1.Product", only when I click on it , it changes to the correct format....Any idea why this is happening or how to work around.
I really appreciate your fast repsonse , Im working on tight deadline
  • 5600
    Could you please provide us a small isolated project that reproduces this issue.
    Anastas
