725
Dragging Activities Across Resources
I need to be able to move activities from one resource to another by dragging. I have set the AllowDragging Property to "AcrossResources", however I am not able to move an activity from one resource to another.
I looked up the help document and here is what I found:
However note that the underlying schedule data connector may impose limitations on whether an activity's resource calendar or resource can be changed or not, in which case regardless of what this property is set to, the underlying schedule data connector restriction will be effective.
However, it does not state what the limitations set by the custom objects are. Is there something we should take care of in the custom objects or in the proeprty mapping to allow this to happen.
Please Suggest.
Thank You,
Hariharan
