I have problem with resizing column when application is running.Example code from my window:
<igDP:XamDataGrid Name="someValues" Grid.Row="1" Theme="Onyx" Width="Auto" Background="{StaticResource GridEditorBrush}" ScrollingMode="Immediate" GroupByAreaLocation="None">
<igDP:XamDataGrid.FieldLayoutSettings>
<igDP:FieldLayoutSettings AllowDelete="False" AutoGenerateFields="False" RecordSelectorLocation="None" MaxSelectedRecords="1" MaxSelectedCells="0">
</igDP:FieldLayoutSettings>
</igDP:XamDataGrid.FieldLayoutSettings>
<igDP:XamDataGrid.FieldLayouts>
<igDP:FieldLayout>
<igDP:FieldLayout.Fields>
<igDP:UnboundField Name="Value1" Label="value 1">
<igDP:Field.Settings>
<igDP:FieldSettings AllowEdit="False" AllowResize="True" CellMinWidth="120" LabelMinWidth="120" LabelMaxWidth="500" CellMaxWidth="500"/>
</igDP:Field.Settings>
</igDP:UnboundField>
<igDP:UnboundField Name="Value2" Label="Value 2">
<igDP:FieldSettings AllowEdit="False" AllowResize="True" CellMinWidth="160" LabelMinWidth="160" CellMaxWidth="500" LabelMaxWidth="500"/>
<igDP:Field Name="Value3" Label="Value 3">
<igDP:FieldSettings AllowEdit="True" AllowResize="True" CellMaxWidth="160" CellMinWidth="500" LabelMaxWidth="500" LabelMinWidth="160"/>
</igDP:Field>
</igDP:FieldLayout.Fields>
</igDP:FieldLayout>
</igDP:XamDataGrid.FieldLayouts>
</igDP:XamDataGrid>
Important for user is to have possibility to increase and decrease columns width. Where can be a problem in this code ?
Hello PoKrec,
Thank you for your feedback.
Thanks for your answer, I tested version 11.1 and it works great.
I have been looking through your sample and I manage to reproduce your behavior. I tested your code with the latest service release for 8.2 and everything was as you explain. I also tried your project with the first version of 8.2 and everything seemed to work ok there. Since this is a retired product we are no longer providing service releases for it, so I can suggest you revert to the RTM version of 8.2 or get the newest release of NetAdvatage which now is 11.1.
You can see the product lifecycle here:
http://ko.infragistics.com/support/product-lifecycle.aspx#ProductLifecycle
Here is a link to our latest product:
http://ko.infragistics.com/dotnet/netadvantage/wpf.aspx#Downloads
Ok it was my mistake but I see that I can only decrease columns and what about increase?
I have some test project for you to test and see where can be a problem with this.
Thank you for your post. I have been looking through the code snippet you provided and I notice that in “Value3” Field you have set the cellmin and cellmax width like this:
CellMaxWidth="160"
CellMinWidth="500"
which causes your issue. To achieve your goal just swap the values and everything will work as expected.
If you have any further questions do not hesitate to ask.
