Quick question... Is there an easy way to let users reposition(drag) a chart legend at runtime so as to unveil any obscured data?
I have been looking into your questions and I can suggest you check the following forum thread which seems to discuss the same topic:
http://forums.infragistics.com/forums/t/67035.aspx
If you need any additional assistance on this matter, please do not hesitate to ask me.
can you provide a simple sample for the floating legend?
The optionspanel from the xamFeatureBrowser does not work in my project. I copied the files OptionsPanel.xaml and OptionsPanel.xaml.cs to my project. But when i add the optionspanel control to my window, only a frame around gets displayed at designe time. And at runtime there is not even the frame!
What is necessary to display the optionspanel as a legend?
Regards
Where can I find the code for the OptionsPanel that the legend is wrapped in?
Hi Graham!
This floating tool pane is great! How can i do that!? There are some examples?
Thank you!
Thanks for your help Graham. The OptionsPanel workaround should do the trick nicely.
