560
Validation Grid Column InvalidValueBehavior in Xaml
How to set Invalid Value Behavior for a column in Xaml. InvalidValueBehavior set below does not work. I am being forced to handle event EditModeValidationError.
<igDP:UnboundField BindingPath="ColumnValue" BindingMode="TwoWay" Name="Depot" Label="XColumn" Visibility="Visible">
<igDP:Field.Settings>
    <igDP:FieldSettings CellMinWidth="75" CellMaxWidth="75" CellWidth="75" EditAsType="{x:Type sys:String}">
 <igDP:FieldSettings.EditorStyle>
     <Style TargetType="{x:Type igEditors:XamMaskedEditor}">
  <Style.Triggers>
      <DataTrigger Binding="{Binding Path=HasChoclates}" Value="True">
   <Setter Property="Mask" Value="####" />
      </DataTrigger>
      <DataTrigger Binding="{Binding Path=HasChoclates}" Value="False">
   <Setter Property="Mask" Value="###" />
      </DataTrigger>
  </Style.Triggers>
  <Setter Property="HorizontalContentAlignment" Value="Right" />
  <Setter Property="InvalidValueBehavior" Value="RetainValue" />
     </Style>
 </igDP:FieldSettings.EditorStyle>
    </igDP:FieldSettings>
</igDP:Field.Settings>
</igDP:UnboundField>
  • 12875
    I don’t see any ValueConstraints in your definition.  I believe that is what is missing for you.
    I created an unbound column with the following xaml:
    <igDP:UnboundField  Name="Depot" Label="YColumn_REVERT" Visibility="Visible">
                           <Style.Triggers>
                                <DataTrigger Binding="{Binding Path=Depot}" Value="True">
                                </DataTrigger>
                                <DataTrigger Binding="{Binding Path=Depot}" Value="False">
                                </DataTrigger>
                            </Style.Triggers>
                                <Setter Property="ValueConstraint">
                                    <Setter.Value>
                                        <igEditors:ValueConstraint>
                                            <igEditors:ValueConstraint.Enumeration>
                                                <x:Array Type="{x:Type sys:Object}">
                                                    <sys:String>True</sys:String>
                                                    <sys:String>False</sys:String>
                                                </x:Array>
                                            </igEditors:ValueConstraint.Enumeration>
                                         </igEditors:ValueConstraint>
                                    </Setter.Value>
                                 </Setter>
                         </Style>
    And loaded the row values in the initializeRecord event.
    When the cells were being edited, the value as modified was “retained” and you are unable to leave the cell.   A message box is displayed and the EditModeValidationError is triggered.  I believe that is the appropriate behavior.
    Let me know what version of our NetAdvantage for WPF you are using and I can test further.  Or if you are expecting different behavior, please let me know.
