Good morning.by default the datagrid infragistisc displays the fields of type Decimal (X) with the symbol $.How do I render the symbol € (euro)?thanks
Perfect. It works fine with it-IT.thanks
Hello again,
The namespace for igEditors is http://infragistics.com/Editors
Looking for your reply
namespace that is igEditors?
thanks
Hello Pranzo,
Thank you for your post. I have been looking through it and I suggest you use the following style for the xamCurrencyEditor:
<Style TargetType="{x:Type igEditors:XamCurrencyEditor}"> <Setter Property="Language" Value="de-DE"></Setter> <Style>
which is used to present Decimal fields in your xamDataGrid. By doing this you will achieve your goal.
