I have the exact same problem as the person in this post http://community.infragistics.com/forums/p/48373/257041.aspx
This posts states:
I have several XamTextEditor/XamComboEditor controls in a TabItemEx. Their values are binded to an object, like this: SelectedItem="{Binding Path=Status, UpdateSourceTrigger=LostFocus, ValidatesOnDataErrors=True}"
The object implements IDataErrorInfo. When the property has an error the control is surrounded by a thin red border. When I activate another tab and then go back to the tab with control with the error the border is gone. Even though object still has an error.
Any ideas?
With a reply of...
I found a work around, I surrounded the control with <AdornerDecorator> tag and the border stays.
I just want to know if there is a better way to do this. I have over 4,000 xamEditors to implement over the next few years and don't feel like wrapping every one of them in an AdornedDecorator.
Thank You
Thank you for the response. I truely appreciate the time you spent explaining it as well. THANK YOU!
You don't have to put an AdornerDecorator around each control - just within the Content of the TabItem. Adorners are managed by the WPF framework and are provided by 1 of 2 elements - a ScrollContentPresenter (i.e. from a ScrollViewer) and an AdornerDecorator. When you change tabs the elements are being unloaded since a tabcontrol only keeps the content of the selected tab item in the visual tree. When the elements are unloaded the wpf framework removes the adorners.
<TabItem Header="Home"> <AdornerDecorator> <Grid>...or what ever is in the tab</Grid> </AdornerDecorator></TabItem>
