I just updated to Infragistics NetAdvantage WPF 2011 Volume 1. The behaviour of the Application Bar on top and the Close, Maximise and Minimize Buttons seems wrong.
Here is what they do:
When I open my application maximized, I get a black application bar and no close button, no maximize button and no minimize button. The buttons are not visible, but they still work if I click in the right place.
If I click on the application icon in the task bar to minimize the application and click it again to maximize it the application bar shows up as the normal aero transparent blue with minimize, maximize and close buttons visible and working.
I would like the aero application bar right from the start.
It works. Thank you
The service release containing the fix for your issue is out, you can download it from: https://ko.infragistics.com/Membership/Default.aspx?panel=Downloads#Downloads
We will be glad to receive a feedback on the outcome.
If you had in mind the XamRibbonWindow issue mentioned in this forum thread http://community.infragistics.com/forums/p/57512/293403.aspx# , the service release that contains the resolution should already be available be for download.
If this doesn’t resolve your issue, please let us know.
I thought it was xamDockManager since that has changed a bit, but the description of the fixed issue is identical with what I am experiencing. So I assume you are right.
Let me know when the service release can be downloaded.
Thank you.
Are you sure you mean xamDockManager? It sounds like you are referring to an issue regarding xamRibbonWindow that has been fixed and will be available in the upcoming SR.
