When I update the MRU list in the application menu and then open the application menu again I have to wait around 10 seconds till the menu finally opens.
So I'm updating the list like this
this.Ribbon.ApplicationMenu.RecentItems.Clear(); for (int i = 0; i < m_MRU.Count; i++) { ButtonTool bt = new ButtonTool(); bt.Click += new RoutedEventHandler(AppMenuMRU_Click); bt.Caption = m_MRU.ElementAt(i); this.Ribbon.ApplicationMenu.RecentItems.Add(bt); }
then wait a bit, then click on the orb and then just sit and wait. After 10 secs the menu finally opens.
Bug in XamRibbon?
Edit: using Infra 11.1
thanks fro trying to track this one down. I tried to break when the issue happens but the call stack didn't show any helpful data so I couldn't investigate any further. And as it fortunately only happens when using the debugger there is no urgency anymore. I'll mark this as answered then.
I am just checking is this still an issue? If you have any questiones on this, please do not hesitate to ask.
Hello LCIGmbH,
We are still not able to reproduce the delay you are describing. I was wondering if you had managed to run the profiler as Andrew suggested in order to verify if there is indeed a performance issue caused by the XamRibbon.
Please let me know if have managed to get more details about this so we can continue investigating it, or you have managed to overcome it on your own.
Maybe you could break while that is happening and see what the callstack is or run a profiler and try to determine what is happening during that interval. I'm not able to reproduce the issue so I cannot say at this point what it might be.
No output. Also it happens not only the first time, it happens every time when you add an item (or rearrange) the MRU list and then click the orb again.
