355
Fields in Child FieldLayout showing incorrect labels
I am databinding a XamDataGrid to a DataView that is part of an ADO.NET DataSet. This DataSet has has a parent/child relation.
The child relationship is showing up as expected.
The issue is that the child field header text is showing up incorrectly! Instead of displaying the DataColumn.Caption these fields are displaying DataColumn.Name
Note that the main field layout is displaying correctly, showing DataColumn.Caption rather than DataColumn.Name
Why is this? Short of manually going in and updating the field's captions what can I do to fix this? (Note that I am using the XamDataGrid as part of a ControlTemplate)
  • 138253
    It has been a while since you have made your post, in case you still need support I will be glad to assist you further. I suppose the other community members can benefit from this answer as well. I have been looking into your post, but I wasn’t able to reproduce your behavior, so I created a sample project, where the Field’s Labels are bind to the DataTabel’s Columns’ Captions. If my sample doesn’t satisfies your needs feel free to modify it, so it reproduces the issue you described, and send it back to me for further investigation.
    xamDataGridDataSet.zip
