I am a have xamdatagrid with parent and child grids. When you move a column to a different location, how do you sync that up with the child grid, so that the child grid column is moved as well.
Thanks. After installing the service update the sample code works.
Hello again,
I have tested the sample with the RTM release of version 9.2 and there ActualPosition property was read-only, as you said. I also tested it with the latest service release of 9.2 and there the property has become mutable, so I suggest you download the latest service release for version 9.2. You can get it from our website’s “My IG”, “My Keys & Downloads” tags:
https://ko.infragistics.com/Membership/Default.aspx?panel=Downloads#Downloads
Yes I saw that link, however the sln in that link uses Field.ActualPosition and that field is readonly. We are using v9.2, has that changed in later versions?
Thank you for your post. I have been looking through it and I suggest you see the following forum thread:
http://community.infragistics.com/forums/p/53090/276218.aspx
which discusses the same issue as yours. Please let me know if this helps you or I have misunderstood you in any way.
