I'm planning to use the XamDataGrid (and maybe other controls) in a larger project of mine.
The solution must have the possibility to run on multiple clients which raises a quetion for me.
Are there any known problems with running the NetAdvantage controls for WPF in both 32 and 64 bit environments with the same build?
Hello Stefan
Thanks for the reply!
I'm working on a pretty large project and it would be a shame if there were any problems with 32bit/64bit when it is ready for release...
Hello Christian,
It has been a while since you have made your post, in case you still need support I will be glad to assist you further. I suppose the other community members can benefit from this answer as well. I have been looking through your post and I can say that there aren’t such issues and the main reason for this is, because our controls are based on Microsofts’ WPF controls. Also, if something come up, I will let you know as soon as possible.
