I have a split pane docked to the right with 2 seprate content panes in it and the same on the bottom for the XamDockManager.Panes. If I "auto hide" 1 of the content panes on the bottom I can not get it back unless I "auto hide" the panes to the right. It apperars at the bottom of the window as a tab, I move the mouse over it, and it comes back into view, but the right side pane buttons are not accessible, it is behind the split pane to the right, so I can not click the "auto hide" to bring it back.
Is there a work around for this or someother property that needs set?
SDI
I'm not aware of any such issues remaining in a WPF application so we would need a sample that demonstrates the issue to understand what is happening in your scenario. The only case I can think of where this may still happen is in an XBAP application because the WPF popups would be behind some HwndHosts but that wouldn't be under our control.
HI Andrew,
I am using latest version 11.2 but still getting same issue? Any ideas what I can do to fix it?
Imad.
Andrew, you are correct! The version we had was 8.2.20082..1002, we updated to .2140 and the pane now appears over the host! This is great! It is also great when you update your software :). I appreciate the direction!!
Thanks!!!
It was a while back but I believe a hotfix for 8.2 included the fix. Try going to "My Infragistics" and then to "My Keys & Downloads" to get the latest SR.
Ouch this is not good - we have version 8.2.20082.1002, what version was the fix in?
