355
MVVM and EventTrigger
I'm trying to relay the Drop event to a command.  Why doesn't the following work...
<Border Background="#f7f7f7" BorderBrush="#ccc" BorderThickness="1" Margin="2" Padding="4" Cursor="SizeAll">
                                        <ig:DragDropManager.DragSource>
                                            <ig:DragSource IsDraggable="True">
                                                <i:Interaction.Triggers>
                                                    <i:EventTrigger EventName="Drop">
                                                        <i:InvokeCommandAction Command="{Binding DataContext.AddChartCommand, ElementName=ReportDocumentView}"/>
                                                    </i:EventTrigger>
                                                </i:Interaction.Triggers>
                                            </ig:DragSource>
                                        </ig:DragDropManager.DragSource>
                                        <TextBlock Text="{Binding DisplayName}"/>
                                    </Border>
Is it because DragSource uses a regular event instead of a routedevent?  Is that a requirement for EventTrigger?  Also, just fyi, I tested the InvokeCommand code on a button's click event and it worked fine.  It just doesn't work when attached to the DragSource.
  • 355
    Ok, that was painful but I figured it out.  Binding inside the DragSource EventTrigger wouldn't work whatsoever (it always returned null for any binding).  The key was to use the new x:Reference binding in .Net 4.0...
    <i:InvokeCommandAction Command="{Binding Source={x:Reference ReportDocumentView}, Path=DataContext.AddChartCommand}"/>
