I have installed the new Service Release 2011 Vol 1 "2026". Now in the Pivot grid is it not possible to drag any field from the PivotDataSelector to the grid and drop it. I use the pivot grid in an WPF Browser Application. If I change back to the libraries "1002" the application works fine with the same source code.
Just to let you know that this issue has already been fixed in the version WPF_11.1.20111.2094 . To download the service release, log in to‘My IG’ tag on our website and select ‘Keys & Downloads’. Select the appropriate tab for this product; then the license key. The available service releases (Hot Fixes) should now be listed on the page.
If you need any additional assistance on the matter, please do not hesitate to ask.
Hello Elena,
thank you for your fast support. Waiting for the new service release.
Regards
Ralf
Hello RalfMenzel,
I tested the described scenarios also with the xbap and I created a case CAS-69852-LFNB8Z for you and link it with the Developer issue ID 83918, so that you can get automatically updated, when a Service Release containing the fix is available for download. You can get the new version from our website’s “My IG”, “My Keys & Downloads” tags: https://ko.infragistics.com/Membership/Default.aspx?panel=Downloads#Downloads
You can also monitor the support ticket’s progress through the “My Support Activity” tag:
https://ko.infragistics.com/Membership/MySupport.aspx .
If you have any additional questions on this please do not hesitate to ask.
I am currently working on this issue. I will update you on my progress by tomorrow.
The issue you have described is caused by drag-and-drop framework. Actually currently we don’t support drag-and-drop for WPF Browser Applications and that’s the reason we have missed this.
Could you please contact our developer support team, so they will create a work item for your case and you can expect it fixed for the next service release.
Regards.
Plamen.
