160
XamDataGrid UI Refresh Issue(PropertyChanged is Firing properly)
Hi All,
 Iam using the XamDatgrid(V10.3) for displaying some columns on the screen. I am facing some issues with the UI getting refreshed even though the bound property is changing. I am using the MVVM pattern. Heres what I'll do.
1. I will make a call asynchronous to a web service to fetch server data and I do one of the following
      a. If the data comes back, I will convert it to a DataTable and bind it to the grid
       b. If the data does not come back, I will bind a dummy datatable to the grid.
The behavior of the grid is really inconsistent. The first time it seems to load the acual/dummy data properly and when i try to refresh with new data its not working. Sometimes even the first time the data is not loading properly
1. I am using the NotifyPropertyChanged Interface in my base class and calling it from the derived viewmodels. Will verify that its working in all my viewmodels.
2. The PropertyChanged Event is NOT NULL AND FIRED PROPERLY.
Following is the xaml for the Grid.
<igDP:XamDataGrid Grid.Row="0" x:Name="_equityRiskForecastGrid" Panel.ZIndex="0" GroupByAreaLocation="None" ScrollViewer.HorizontalScrollBarVisibility="Hidden" ScrollViewer.CanContentScroll="False" DataSource="{Binding Path=EquityRiskForecast,UpdateSourceTrigger=PropertyChanged}" RecordLoadMode="LoadOnDemand" RecordContainerGenerationMode="Virtualize">
The FieldLayouts are defined beforehand and I have tried the different options for RecordContainerGenerationMode,RecordLoadMode etc like OnDemand,Virtualize. Nothing seems to work.
Can anyone help me out with this issue ASAP?Really at my Wits End here.Thanks a million in advance
Ram
