660
mm/yyyy Format does not seem to work with a Date Property for XamDateTimeEditor
 For instance if the value from my database is 04/01/1997 then my xamEditor shows 04/0001
 If I change the mask to yyyy/mm then it shows 0004/01
However, if I change my Property (shown below) to a type of string and convert the text manually by building a string from the date it works correctly. Can someone explain why this isn't working?
Here is what my XAML looks like
<igEditors:XamDateTimeEditor Mask="mm/yyyy" Text="{Binding Path=member.init_dt, UpdateSourceTrigger=LostFocus, ValidatesOnDataErrors=True}" >
Here is what my Code Behind looks like
Public Property init_dt As Nullable(Of Date)
Get
If currentRecord Is Nothing Then
Return Nothing
Else
If IsDBNull(currentRecord("init_dt")) = False Then
Dim odte As Date = currentRecord("init_dt")
Return odte
Else
Return Nothing
End If
End If
End Get
Set(ByVal x As Nullable(Of Date))
Dim dte As Object
If x IsNot Nothing Then
dte = x
Else
dte = DBNull.Value
End If
If Not currentRecord Is Nothing Then
currentRecord("init_dt") = dte
End If
End Set
End Property
