In my application I have multiple ribbon tabs and I also make use of contextual tabs. When the contectual tab gets closed after I was working with it (i.e. I activated the contextual tab by clicking on it), the first (regular) will we selected. Is there a way to specify that for example the second tab should be selected in this case instead of the first tab?
Kind regrads,
Rainer
Thanks for the quick reply.
No that is not possible. The Microsoft UI guidelines specifically state that the 1st tab must be selected when the contextual tabs are dismissed.
