Hello,how can I rename the groups (Measures, CustomerID, ...) from the data selector?How can I delete the listBox/comboBox above and below from OrdersX?
Alexander
To rename default names you should define your own hierarchy. Here is a link how to do it.
About your second question, the easiest way is to use blend for applying new Style of DataSelector. Also you can read this thread.
Todor
