225
Hierarchical data and field layout question
Hi guys,
  My data source is an ObservableCollection<IInterface> and this IInterface has a property called Items of type ObservableCollection<IInterface>. The problem that i have is showing the children without the header and share the same column layout for the parent. I have code to handle AssigningFieldLayoutToItem and i am creating a second fields layout there based on the parent layout. The problem is i need to reflect the changes to the parent/default layout into the child/second layout, and by changes i mean column position, column resizing.
 I am attaching an image of what i would like to achieve. Any suggestions?
 Stefan
