Hello, I'm looking to see if it's possible to save customizations of a datagrid to a stream such as memorystream, and how it would be tied in for load/unload, so that when a datagrid is unloaded (such as when changing to a new tab or a secondary grid) the grid can then have the same customizations when it's reloaded once more. Thank you!
I didn't even notice that it supported saving to and from strings, I guess I should double-check the API more closely then in the future! That would work perfectly in that case. Thank you!
I have been investigating into your requirement, however there doesn’t seem to be such a built-in option. If your goal is to not have to create files I can suggest you save and load the customization to and from a string value like so:
string stringCustomizations;
private void Button_Click_1(object sender, RoutedEventArgs e)
stringCustomizations = xamDataGrid1.SaveCustomizations();
private void Button_Click(object sender, RoutedEventArgs e)
xamDataGrid1.LoadCustomizations(stringCustomizations);
Actually you shouldn’t have trouble saving the string to memory stream if that is a need be approach.
Please let me know if you require any further assistance on the matter.
