I want to change the background the forecolor fo content Pane Header when it is displayed inside toolwindow.
Can you pls point me to the brush/style for the same?
Thank you for your post. I have been looking through it and I suggest you use the following style for the PaneHeaderPresenter:
<Style TargetType="{x:Type igDock:PaneHeaderPresenter}"> <Setter Property="Foreground" Value="Red"/> <Setter Property="Background" Value="YellowGreen"/> </Style>
You can also add trigger to check if the pane is docked or set to AutoHide and then set the Foreground and Background colors.
Looking forward fort your reply.
any pointer?
