850
XamComboEditor initialization problem
I have a simple user select screen where an admin can emulate another user from a drop-down list. I would like to use a xamComboEditor because it seems quicker when displaying a large amount of data but for some reason it doesn’t seem to bind the SelectedIndex when it initializes.
I have put a standard combobox and a xamComboEditor next to each other to illustrate the issue
        <ComboBox ItemsSource="{Binding UserListView}"
                  SelectedIndex="{Binding UserSelected}"/>
        <igED:XamComboEditor ItemsSource="{Binding UserListView}"
When the dialog shows, the combobox shows the selected item properly but the xamComboEditor is left blank.
However if I then change the combobox’s selected item using either of the comboboxes it updates fine, showing that the binding are set correctly.
So the question really is how can I force the xamComboEditor to use it's bindings as the dialog is initialized?
