I got another question.
I include Openstreetmaps via
<ig:XamMap.MapTileSource><ig:OpenStreetMapTileSource x:Name="openStreetsTileSource" /></ig:XamMap.MapTileSource>
But the maximum zoom factor is smaller than in the internet on openstreetmaps.org
Additionally it's not that sharp like on the website
I think I just cannot get the last step.
thanks,
henning
Hello Henning,
We have been looking into your requirement and since our Data Visualization controls are cross-platform, in order to provide means of creating consistent WPF and Silverlight counterparts of a project, we have had to comply with a Silverlight rendering limitation. However we have decided that it would be a good improvement to have this fixed for the WPF controls and so I have logged this with development under ID: 86295 and I have also created a support ticket on your behalf: CAS-72144-TNYQGW and have linked the development issue to it, so that you can get automatically updated, when a Service Release containing the fix is available for download. You can get the new version from our website’s “My IG”, “My Keys & Downloads” tags: https://ko.infragistics.com/Membership/Default.aspx?panel=Downloads#Downloads
You can also monitor the support ticket’s progress through the “My Support Activity” tag: https://ko.infragistics.com/Membership/MySupport.aspx
Thank you very much!
Hi Henning,
I have contacted our Development support team on your behalf and they will try to resolve the issue.
Ivan Kotev
thanks for your answer.
I thougt the xammap is made for adding mapelements, isn't it? an empty geo-imaginery map I can view in the internet.
Is the restriction also on bingmaps or just on openstreetmap? Cause this restricted ZoomFactor won't be enough for our goals.
i will make a request for opening this restriction, any clue, how long such request will last, so is it worth waiting for it?
Kind regards
Henning
Hi again,
By XamMap's design, when MapElements are added to a МapLayer, the WindowZoomMaximum is restricted to a specific value, so the behaviour you observe is normal. When only tile source is used, as it is the case in the sample application I sent, there is no such restriction.
If you like, you can submit a feature request on implementing this functionality, using the following form:http://devcenter.infragistics.com/protected/requestfeature.aspx
Best Regards,Milana Zhileva
