Hi there,
when sending float values into a xamChart we currently experience that the decimal point is not shown in contrast to the datatype Decimal, where everything is correct. We even think that the converting is not only wrong for display, but also for calculation, because the graphs look different depending on the datatype. Our development environment is set to European locales (DE-AT, CZ etc..)
I would understand if it would be a permanent problem, but why does the behaviour change with the datatype?
regards Florian
Hello Florian,
I have logged development issue 88664 regarding XamChart showing incorrect format for float type data in European locale. I have sent you more details in the case.
Regarding XamChart I am in the process of logging development issue in our system. We are including xamDataChart in the NetAdvantage for WPF LOB for 11.2 product release. So from 11.2 xamDataChart will be part of NetAdvantage for WPF.
You may check out features of xamDataChart in case if you would like to move to xamDataChart in future.
Asma,
thanks for opening a case for us. I think we are not able to use XamDataChart as it belongs to the WPF Visualization license which we do not own (and it´s existence was just now revealed to me by searching for this xamDataChart on your homepage...) - We would love to see the xamChart being fixed.
Regards Florian
I have tested this issue using XamDataChart and it shows the float data correctly. I would suggest you to use xamDataChart instead of XamChart.
Please let me know if you have any questions on this matter.
Thank you for reporting this issue to us. I am able to reproduce the behaviour you mentioned in a sample. I am going to log this as a development issue in our system for further investigation. I have created a case for you and the case number is CAS-72371-3YNDV2.
Please save this case number for future references. You’ll be able to access this case from the My Support Activity page: <https://ko.infragistics.com/Membership/MySupport.aspx>
I will send you more information through the case.
