570
style carrying from bound grid to report
I have a xamdatagrid with datasource a bound to a table.defaultview and it works ok but I've played around with some style setting such as centering in a column and text color (neither of which I can get to work like I want) BUT...the issue is this..if I have some datapresenter style in the xaml for my grid as below I see it work to some degree when the datagrid is displayed on my control but when I send it to the xamreportpreview and print it the color for the text is gone and things seem to revert back  to not have the style applied....Is there something I need to do to force the style at some later time as the bound table is refreshed or something?
igDP:XamDataGrid.Resources>
<Style TargetType="{x:Type igDP:CellValuePresenter}" ><Setter Property="Foreground" Value="{Binding Path=Cells[3].Value, Converter={StaticResource textColorConverter}}"/>
</Style>
  • 30945
    Sincerely,
    Krasimir
    Developer Support Engineer
    www.infragistics.com/support
  • 30945
    Suggested Answer
    I have created a sample application  that demonstrates using the XamReportPreviewer in order to generate preview of the XamDataGrid. I have added a Style for the CellValuePresenter similar to the style that you have posted. The XamReportPreviewer displays the XamDataGrid with the style for the CellValuePresenrter. I have attached the sample application and also attached a screenshot of the behavior that I am getting.
    Please let me know if you can reproduce the same behavior using the sample application that I have attached, or I have misunderstood you in any way.
    Sincerely,
    Krasimir
    ReportingWithStyle.zip
