I've developed an application to show events to users - I use XamOutlookCalendarView to display items. I created my own data class to store event data (Event class, which has similar property names as Appointment class to be able to use default mapping in XamScheduleDataConnector) and I set the AppointmentItemsSource to an ObservableCollection<Event>. This works fine.
But now I have to implement filtering and I decided to use ListCollectionView (by setting the SourceCollection to the previously mentioned ObservableCollection<Event>). When I changed the XamScheduleDataConnector settings to use this ListCollectionView I get the following error:
Error Details:1) Application configuration error. The functionality is not supported. Error Details: The following property mappings are missing for ActivityBase items:IdOwningResourceIdStartEnd2) The following property mappings are missing for Appointment items:OwningCalendarId
When I change setting to use defined mappings instead of the default, I get the similar error.
I seached lot for solution but I haven't found one - so I ask your help.
Thanks,Istvan
Hello Istvan,
I am going to log this as a development issue in our system. I have created the case CAS-72812-39HHG3 for you on this issue. You may update this case using My support activity page <https://ko.infragistics.com/Membership/MySupport.aspx>
Please let me know if you have any questions on this matter.
I have logged development issue 89492 on this issue. I will update you with any new information after the review. I have sent you more details regarding development issue through the case.
This issue has now been resolved in the latest service release.
Sincerely,ValerieDeveloper Support Engineer Infragisticswww.infragistics.com/support
