270
XamOrgChart Expand
Hey!
My first issue is the following:
I bind my OrgChart's DataContext to a ViewModel.
I want all nodes be collapsed when the Chart is shown first time.
I tried:
Dim allNodes = NetzChart.RootNode.HighlightChildren(NetzChart.ActualDepth)
For Each node As OrgChartNode In allNodes
  node.IsExpanded = False
Next
But that throws an StackOverflowException even with small data, or does not show the orgChart at all.
My second issue:
Is there a OnNodeExpanded Event or something similar to that? Or any workaround to achieve this behaviour? I want not to load the childs of one node of the chart until the parentnode is expanded by the user.
Thanks for your help!
Regards
Henning
  • 138253
    Hello Henning,
    Thank you for your post. I have been looking through it and I suggest you use a recursive function in order to iterate trough all nodes of the XamOrgChart. The function may look like this:
    private void Iterate(OrgChartNode node)
        if (node.ChildNodes != null)
            foreach (var item in node.ChildNodes)
                Iterate(item);
        if(node.Level != 0)
        node.IsExpanded = false;
    And you can call it in the Loaded event of the XamOrgChart with its RootNode as argument. As for your other question I can suggest you use the NodeControlAttached event of the control, which occurs when a Node is Expanded or Collapsed.
    Feel free to write me if you need further assistance on this matter.
