I'm trying to adapt this example (http://community.infragistics.com/forums/p/50183/264009.aspx#264009) to the XamRadialGauge control. I've done this for the XamLinearGauge control without issue. I almost have it working for the radial gauge, however the needle refuses to display.
I've attached a demo project that illustrates a simplified version of what I'm trying to accomplish. The main view creates two XamRadialGauge controls, both initialized with identical gauge elements. The first is initialized through a dependency property, the second through the view constructor. All of the elements in the unbound gauge appear; all of the elements *except the needle* appear in the bound gauge.
Can someone shed some light on this one?
Obliged,
jim
Valerie;
Confirmed that the service release addresses the issue. Thanks for the help.
Thanks Valerie;
I'm downloading the SRs now and will verify, thanks!
Jim
Hello Jim,
I tested in Build 11.1.20111.2053 and this appears to be an issue particular to that build. Please download the latest service release to resolve this issue.
Sincerely,ValerieDeveloper Support Engineer Infragisticswww.infragistics.com/support
11.1.20111.2053
What version (build number) of NetAdvantage for WPF are you using?
