490
wpf Radio Button DataBindings
I have two radiobuttons on my view and there IsChecked property is binded to the ViewModel property IsDynamic , problem
is that when i change the selection of first radion button first time the binding works ,but when i check another
radion button the IsChecked property is not updated. I am using the enum boolean converter. My xaml file
is
RadioButton Grid.Column="0" Content="Static" IsChecked="{Binding Path=IsDynamic, Converter={StaticResource enumBooleanConverter },ConverterParameter=Static,Mode=TwoWay}" TabIndex="1" GroupName="Static"/>
<RadioButton Content="Dynamic" Grid.Row="1" Margin="0,30,96,16" IsChecked="{Binding Path=IsDynamic, Converter={StaticResource enumBooleanConverter},ConverterParameter=Dynamic,Mode=TwoWay}" IsEnabled="{Binding IsDynamicViewEnabled}" TabIndex="2" Width="61" IsHitTestVisible="False" Checked="RadioButton_Checked" GroupName
="Dynamic"/>
and the EnumBooleanConverter is
public object Convert(object value, Type targetType, object parameter, System.Globalization.CultureInfo culture)
string parameterString = parameter as string;
if (parameterString == null)
return DependencyProperty.UnsetValue;
if (Enum.IsDefined(value.GetType(), value) == false)
object parameterValue = Enum.Parse(value.GetType(), parameterString);
return parameterValue.Equals(value);
public object ConvertBack(object value, Type targetType, object parameter, System.Globalization.CultureInfo culture)
return Enum.Parse(targetType, parameterString);
The isDynamic property on ViewModel is as follows
public
AccountSetDynamic
IsDynamic
set
//this.currentAccountSet.IsDynamic = value;
if (value.Equals(AccountSetDynamic
.Dynamic))
this.CurrentAccountSet.IsDynamic = true
else if(value.Equals(AccountSetDynamic
.Static))
this.CurrentAccountSet.IsDynamic = false
this.isDynamic = value
this.RaisePropertyChanged(() => this
.IsDynamic);
get
return this
.isDynamic;
and the ENUM is as follows
public enum AccountSetDynamic
Static=0,
Dynamic=1
i cannot figure out where i am doing wrong ,please help out
