570
Difference between 11.1.20111.2094 -v- 11.1.20111.1002 ?
What is the difference between Infragistics WPF (LOB) 11.1.20111.2094 -v- 11.1.20111.1002 ? Is there a list of bugs fixed in .2094 ?
Two developers have installed Infragistics v11 at slightly different times and ended up with different versions. I couldn't find this list of fixed bugs. I saw a file WPFLOB_EN_FixedBugs_SR11_7.pdf but that only mentioned 2011.1, not the .2094 service release.
Thanks.
  • 2263
    The PDF you named is the list of bug fixes in 2094.  The PDF(s) that ships with a patch lists the bugs fixed in that patch from the previous patch.  Unfortunately, at this time it is not a cumulative listing of all the changes from the RTM to that patch.  I will put in a suggestion that we try to start providing a cumulative list.
