360
How to set the Label of a Field Correctly while DataBound
I've got a problem with the Field Label. I want to change the Header Text of the XamlDataGrid, but nothing changed here the xaml code:
<Grid x:Name="rows_grid" HorizontalAlignment="Stretch" VerticalAlignment="Stretch">
<my:XamDataGrid Height="{Binding ElementName=rows_grid,Path=Height}" AutoFit="True" DataSource="{Binding Result, UpdateSourceTrigger=PropertyChanged}"
        Name="xamlGrid" IsSynchronizedWithCurrentItem="True"
        ActiveDataItem="{Binding Mode=OneWayToSource, UpdateSourceTrigger=PropertyChanged, Path=RowObject}" IsGroupByAreaExpanded="True" MouseRightButtonDown="xamlGrid_MouseRightButtonDown"
<igDP:XamDataGrid.ViewSettings>
<igDP:GridViewSettings />
</igDP:XamDataGrid.ViewSettings>
<my:XamDataGrid.Resources>
</my:XamDataGrid.Resources>
<my:XamDataGrid.FieldSettings>
<my:FieldSettings AllowEdit="False" CellClickAction="SelectRecord"  >
</my:FieldSettings>
</my:XamDataGrid.FieldSettings>
<my:XamDataGrid.ContextMenu>
<ContextMenu>
    <MenuItem
        Header="{Binding Converter={StaticResource MyLocalizationConverter}, ConverterParameter=Maintab.Rows.ContextMenu.MenuOpenItem}"
        Command="{Binding ContextFileNameOpenClickCommand}"/>
</ContextMenu>
</my:XamDataGrid.ContextMenu>
<my:XamDataGrid.FieldLayoutSettings>
<my:FieldLayoutSettings AutoGenerateFields="False"  AutoFitMode="Always"/>
</my:XamDataGrid.FieldLayoutSettings>
<my:XamDataGrid.FieldLayouts>
<my:FieldLayout>
    <my:FieldLayout.Fields>
        <my:Field  Name="SalesAgentSK"
                  Label="{Binding Converter={StaticResource MyLocalizationConverter}, ConverterParameter=Maintab.Rows.GridLabel.SALogInName}"
                  Visibility="Visible" AutomationProperties.Name="A">
            <!--<my:Field.Settings>
                <my:FieldSettings EditorType="{x:Type igEditors:}" CellClickAction="SelectRecord">
                    <my:FieldSettings.EditorStyle>
                        <Style TargetType="{x:Type igEditors:XamTextEditor}" >
                            <Setter Property="ValueType" Value="{x:Type sys:String}"/>
                        </Style>
                    </my:FieldSettings.EditorStyle>
                </my:FieldSettings>
            </my:Field.Settings>-->
        </my:Field >
        <my:Field Name="SALogInName"
                  Visibility="Visible" >
            <my:Field.Settings>
                <my:FieldSettings EditorType="{x:Type igEditors:XamTextEditor}" CellClickAction="SelectRecord">
                        </Style>
                </my:FieldSettings>
        </my:Field>
        <my:Field Name="SAName"
                  Label="{Binding Converter={StaticResource MyLocalizationConverter}, ConverterParameter=Maintab.Rows.GridLabel.SAName}"
                  Visibility="Visible">
            <my:Field.Settings>
                        </Style>
                </my:FieldSettings>
        </my:Field>
        <my:Field Name="OrderNumber"
                  Label="{Binding Converter={StaticResource MyLocalizationConverter}, ConverterParameter=Maintab.Rows.GridLabel.OrderNumber}"
            <my:Field.Settings>
                        </Style>
                </my:FieldSettings>
        </my:Field>
        <my:Field Name="OrderTicketNo"
                  Label="{Binding Converter={StaticResource MyLocalizationConverter}, ConverterParameter=Maintab.Rows.GridLabel.OrderTicketNo}"
            <my:Field.Settings>
                            <Setter Property="ValueType" Value="{x:Type sys:Int32}"/>
                        </Style>
                </my:FieldSettings>
        </my:Field>
        <my:Field Name="OrderPrice"
                  Label="{Binding Converter={StaticResource MyLocalizationConverter}, ConverterParameter=Maintab.Rows.GridLabel.OrderPrice}"
            <my:Field.Settings>
                            <Setter Property="ValueType" Value="{x:Type sys:Double}"/>
                        </Style>
                </my:FieldSettings>
        </my:Field>
        <my:Field Name="OldTurnover"
                  Label="{Binding Converter={StaticResource MyLocalizationConverter}, ConverterParameter=Maintab.Rows.GridLabel.OldTurnover}"
            <my:Field.Settings>
                        </Style>
                </my:FieldSettings>
        </my:Field>
        <my:Field Name="OrderDate"
                  Label="{Binding Converter={StaticResource MyLocalizationConverter}, ConverterParameter=Maintab.Rows.GridLabel.OrderDate}"
            <my:Field.Settings>
                            <Setter Property="ValueType" Value="{x:Type sys:DateTime}"/>
                        </Style>
                </my:FieldSettings>
        </my:Field>
        <my:Field Name="PathFileName"
                  Label="{Binding Converter={StaticResource MyLocalizationConverter}, ConverterParameter=Maintab.Rows.GridLabel.PathFileName}"
            <my:Field.Settings>
                            <Setter Property="ReadOnly" Value="True"/>
                        </Style>
                </my:FieldSettings>
        </my:Field>
    </my:FieldLayout.Fields>
</my:FieldLayout>
</my:XamDataGrid.FieldLayouts>
<my:XamDataGrid.InputBindings>
<MouseBinding  Gesture="LeftDoubleClick" Command="{Binding SelectedRowCommand}" CommandParameter="{Binding ElementName=xamlGrid,Path=SelectedRow.ListObject}"/>
</my:XamDataGrid.InputBindings>
</my:XamDataGrid>
Any ideas?
Thank in advance
