Hi, i'm using a XamDataGrid and I've retemplated the grid to have a checkbox on the record selector, but one side effect was I lost the built in field chooser button because it shares the same real estate as the checkbox. What I'd like to do is add a little button somewhere else in my application that will launch the field chooser window, is it possible to do this? Thanks.
It has been a while since you have made your post, in case you still need support I will be glad to assist you further. I suppose the other community members can benefit from this answer as well. I have been looking through your post and I suggest you use the ShowFieldChooser method of the XamDataGrid to show the FieldChooserDialog.
