Does anyone know if Is it possible to change the date format in the XamScheduleView to include the day name alongside the date?
Many thanks.
Do you have any other questions on this matter?
Sincerely,ValerieDeveloper Support Engineer Infragisticswww.infragistics.com/support
Diyan is correct that we use the long date format by default but there are a couple of additional options. That element is the ScheduleViewDayHeader element. By default it contains a ScheduleDateTimePresenter where the DateTime property is bound to the element's Date property and uses the LongDate format.
Hi Urfan,
This date format is dependent on the Regional Settings of your OS since the ScheduleDateTimePresenter is using Long Date format. You can change it here:
Hi Diyan,
Thanks for replying. Here is a screenshot indicating what I want to be able to change:
Many thanks,
Urfan
I am not sure exactly what you mean. Can you send a screenshot of the part of the XamScheduleView that you want to change its date format?
Diyan Dimitrov
