When drag & drop is enabled for xamDataTree in XBAP, the background of the dragged item becomes black. I use XamDataTreev10.3.
I need the background to remain unchanged, so the dragged item is readable.
The attached please find the sample solution to re-produce my issue.
Any help is greatly appreciate it!
Hi lilys,
Soon there will be new SR available with fix for that problem! When it is available you could try it out and let us now if everything is ok with your application! Thank you in advacne!
Nikola.
