I'm having problems with the CategoryDateTimeXAxis sort order of items when I have missing data. Without missing values the plot looks just fine, but as soon as I add the missing value to my sequence, lines are no longer drawn between points in ascending date order.
Attached is a project that can replicate this problem.
Thanks for you help.
Jon
Thanks Petar, thats a great work around for me.
Hello Jon,
There doesn’t seem to be an estimated date yet and also I couldn’t think of a work around as you asked, however until a new Service Release is available I can suggest you revert to the original RTM version of 11.1, which also works as you expected it to. In order to revert back I can suggest you follow this forum post: http://community.infragistics.com/forums/p/60961/309624.aspx
Please let me know if I can be of any further assistance.
That's great. Your guys are on top of things!
I don't see an expected release date for this product. I really needed something by the end of this week. Do you have any ideas for a work around to this issue?
I have been looking into your issue and after modifying the sample I was about to log it with development:
However when I tested this with the latest internal build it turned out that development has already taken care of it:
and you will be able to download the fix with the upcoming Service Release. Here is a link you can reference for the upcoming Service Release shipping dates: http://ko.infragistics.com/support/documentation.aspx#ServiceReleases
