after upgrading from V10.3 to V11.1 i get the following warning:
Warning 4 Found conflicts between different versions of the same dependent assembly.
Visual Studion wants to fix that problem by adding a binding redirect record to the App.Config file:
<dependentAssembly>
<assemblyIdentity
name="InfragisticsWPF4.Documents.Excel.v11.1"
publicKeyToken="7DD5C3163F2CD0CB"
culture="neutral"/>
<bindingRedirect
oldVersion="0.0.0.0-11.1.20111.2113"
newVersion="11.1.20111.2113"/>
</dependentAssembly>
The versions look very similar. What causes this problem?
Best
cew3
There is not an audio connection available in the session, but you can send me your phone number through the CHS and I will contact you tomorrow before the session starts.
Great! But what about audio?
In this case the session will be at 9:00 AM (UTC + 1 ), and 5 minutes before that you will receive the security code to your email, with which you will be able to log in. Also, the automated email showed you 10 o’clock, because I edited my post after post it.
Ok, 9:00 AM (UTC+1) would be fine.
BTW: the automated email from your forum talks about 10:00 AM, bug or feature? :-)
What about audio?
Hello again,
I am available after 8:00 AM, according to your time zone, so please let me know when it is possible for you to do the session, according to your time zone.
