We are receiving intermittent errors when loading data into the datapresenter. We have eliminated all other variables including windows updates and any bugs in our software. Are there any known issues with this?
We are using a brand new Windows 7 computer with .Net 4 installed. InfragisticsWPF4.v10.3.dll files. Attached are the errors received.
Thank you!
Yes that is where you would obtain the hotfix.
Yes, it is the same call stack. The version we are using and what is on the client is 10.3.20103.1003. How do we get this hotfix? In My Keys/Downloads section?
Is it the same callstack that you provided above? If so then it looks like this was addressed in a hotfix a while back - specifically in any build from 10.3.20103.2116 or later which was released back in February. Can you check what version of the assembly is being loaded on the system that is having the problem?
Thank you for responding. This is not corrected yet. We are unable to reproduce the problem in debug mode, it only occurs in production so it will be difficult to create a sample project. What other information can I provide?
Thank you.
I am just checking if you got this worked out or you still require any assistance or clarification on the matter.
