Hi
I have a Carousel list box that displays items using an item template. the item template has a few controls like image and text block. How can I get the text property of the text block control for a given Carousel list item.
I need to loop through the list and set list items to invisible if the items (TextBlock control) dont contain any text.
thanks
Hi -
Rather than searching through the visible elements in code this is something you would typically do with a trigger in the Item Template itself. For example, you could use a DataTrigger to trigger off the value that the TextBlock is bound to and set the Visibility of the root element in the Item Template to Collapsed if the value is empty.
Joe
