Hi
I bind my own object to the "XamDataPresenter", my object looks like this:
Class A
public List<A> Children;
public string ColumnA,ColumnB,ColumnC....
It's a two level structure. If I set AutoGenerateFields to true, the Presenter will show the two level structure correctly.
But if I try to apply the FieldLayouts to customize the Presenter . I'll loss the second level information
How can I keep two level structure while customize the field layouts?
Sincerely,
Krasimir
Developer Support Engineer
www.infragistics.com/support
I have been reading through your description and when you are creating the FieldLayouts for the XamDataGrid with AutoGeneratedFields set to false you should include a Field in the first hierarchy level which will represent the child data. For example when you are creating fields for your “Class A” you should include the following field in the FieldLayout:
<igDP:Field Name=”Children”/>
I am attaching a sample application which shows how you can define the FieldLayouts for two level hierarchy for XamDataGrid in XAML and in code behind.
If you need any further assistance please do not hesitate to ask.
