I do not want to specify width for each and every column(Field) that I am showing in a grid.
But, I want to limit a minimum width for "all" columns of a grid. So that, I only tamper the default width of a column if it is less than the Minimum width that I want all columns to have. Is that possible?
Thanks.
Hello Vikram,
I can suggest you add a Style for the CellControl and set its MinWidth Property like this:
<Style TargetType="{x:Type ig:CellControl}"> <Setter Property="MinWidth" Value="250"/> </Style>
Hope this helps you.
How i do same (min width to all cols) with XamGrid? i have 100 columns so i want to do this with one step
Is it possible to specify CellMinWidth in Percentage. I cannot specify a fixed width as the end users have different monitor sizes.
The ask is to have a autofit functionality while load and if the user resizes the column the scrollbar should appear.
Thank you
Thank you for your post. I have been looking through it and I suggest you set the XamDataGrid’s FieldSettings CellMinWidth Property. Please let me know if this is what you are trying to achieve or I have misunderstood you in some way.
