675
Cannot StartEditMode for activeCell?
Hi, there
We are using Infragistics WPF4 version 10.3. And I'm running into this issue that I desparately need some help. Here's the requirement:
  1. I'm using XamDataGrid to present some data. AllowAddNew=true, UpdateMode="OnRecordChangeOrLostFocus"
  2. Only new record is editable. In another word, user can insert new record, but not edit existing record. They do have the option to delete a record through a delete image at the end of each row.
  3. We are using a customized editor for the first cell of our data, although I don't think this is the issue.
  4. We have a couple cells with AllowEdit set to false.
  5. When user tab through the fields, I want to skip the fields that are disabled (AllowEdit=false).
  6. The last field is also disabled, so when that field is skipped, I listen to the RecordUpdating event for error checking, and RecordUpdated event to save data. These all work fine.
  7. One more thing I need to do is that when the currentAddRecord is saved, I want to move the focus to the new currentAddRecord, and set the first cell into edit mode.
  8. What I did was to listen to ExecutedCommand for CellNextByTab command, if the current cell is disabled, execute another CellNextByTab to skip current cell.
  9. When I reach to the last cell of the row, I still need to skip (because last cell is disabled). The save is handled in RecordUpdated event. But the moving focus to new record part is handled in ExecutedCommand event. Here's my code:
this.gridWantListItems.ActiveRecord = gridWantListItems.RecordManager.CurrentAddRecord;
this.gridWantListItems.ActiveCell = gridWantListItems.RecordManager.CurrentAddRecord.Cells[0];
//CellValuePresenter cvp = CellValuePresenter.FromCell(gridWantListItems.ActiveCell);
//cvp.Editor.StartEditMode();
// enter edit mode
this.gridWantListItems.ExecuteCommand(DataPresenterCommands.StartEditMode);
The problem is that the cell does not go into edit mode. The same code executes in grid Loaded event, and the cell was put in edit mode. But here it does't. Notice the commented out line of CellValuePresenter code. If I uncomment that code, I can see cvp is null. Could this be the reason that StartEditMode does not put my cell into edit mode?
Any suggestion on how I can get the cell into edit mode?
Thanks.
