I am using the code below, code that I modified from XamCarouselPanel, to move items to the left and right but does not work. The Navigation Control works with the Mouse - I just want to emulate what via Tocuh what I can do with the Mouse but with Touch instead.
Here is the XAML and C# code:
<igDP:XamDataCarousel Grid.Row="2" x:Name="productCarousel" DataContext="{Binding}" DataSource="{Binding ProductDataView}" TouchDown="ProductCarouselTouchDown" TouchEnter="ProductCarouselTouchEnter" TouchLeave="ProductCarouselTouchLeave" TouchMove="ProductCarouselTouchMove" GotTouchCapture="ProductCarouselGotTouchCapture" RenderTransformOrigin="0.5,0.5" MouseDown="ProductCarouselMouseDown" TouchUp="ProductCarouselTouchUp" ClipToBounds="False" CellActivated="ProductCarouselCellActivated" RecordActivated="productCarousel_RecordActivated" UpdateMode="OnCellChange" AutoFit="False" SelectedItemsChanged="productCarousel_SelectedItemsChanged" CellChanged="productCarousel_CellChanged" IsNestedDataDisplayEnabled="False" Initialized="productCarousel_Initialized" Theme="" FontFamily="Calibri" FontSize="10.667" GroupByAreaLocation="None" InitializeRecord="ProductCarouselInitializeRecord" Margin="0,8,41.333,8" ScrollingMode="Immediate"> <igDP:XamDataCarousel.Resources> <Path x:Key="HorizontalPath" x:Name="horizontalPath" Margin="0,0,0,0" HorizontalAlignment="Left" VerticalAlignment="Top" Height="Auto" Width="Auto" Stretch="Fill" Opacity="1" Data="M 9,250 C9,250 491,250 491,250 " Stroke="#FFB4B4B4" StrokeThickness="1"/> <Path x:Key="MACCarousle" x:Name="horizontal" Margin="1,1,1,1" HorizontalAlignment="Left" VerticalAlignment="Top" Height="Auto" Width="Auto" Stretch="Fill" Opacity="1" Data="M 9,250 C9,250 491,250 491,250 " Stroke="#FFB4B4B4" StrokeThickness="1"/> </igDP:XamDataCarousel.Resources> <igDP:XamDataCarousel.ViewSettings> <igWindows:CarouselViewSettings ItemPath="{DynamicResource HorizontalPath}" IsNavigatorVisible="True" ItemHorizontalScrollBarVisibility="Disabled" ItemVerticalScrollBarVisibility="Disabled" ReserveSpaceForReflections="False" OpacityEffectStopDirection="UseItemPath" ScalingEffectStopDirection="UseItemPath" UseOpacity="True" ItemPathPadding="50,0,50,152" ItemPathPrefixPercent="0" ItemPathSuffixPercent="0.15" ItemSize="128,128" ItemsPerPage="20" ItemPathRenderBrush="#77000000" UseScaling="True" IsListContinuous="True" HeightInInfiniteContainers="200" WidthInInfiniteContainers="200" ItemPathHorizontalAlignment="Stretch" ItemPathVerticalAlignment="Stretch" ItemTransitionStyle="AdjustSizeAndOpacity" ShouldAnimateItemsOnListChange="True" AutoScaleItemContentsToFit="True" ItemPathAutoPad="False" ItemPathStretch="None"> <igWindows:CarouselViewSettings.ItemPathRenderPen> <Pen DashCap="Round"/> </igWindows:CarouselViewSettings.ItemPathRenderPen>
<igWindows:CarouselViewSettings.OpacityEffectStops> <igWindows:OpacityEffectStopCollection> <igWindows:OpacityEffectStop Value="0"/> <igWindows:OpacityEffectStop Offset="0.1"/> <igWindows:OpacityEffectStop Offset="0.6" Value="1"/> <igWindows:OpacityEffectStop Offset="1" Value="0.1"/> </igWindows:OpacityEffectStopCollection> </igWindows:CarouselViewSettings.OpacityEffectStops> <igWindows:CarouselViewSettings.ScalingEffectStops> <igWindows:ScalingEffectStopCollection> <igWindows:ScalingEffectStop Value="0"/> <igWindows:ScalingEffectStop Offset="0.45" Value="0.8"/> <igWindows:ScalingEffectStop Offset="0.55" Value="2"/> <igWindows:ScalingEffectStop Offset="0.65" Value="0.8"/> <igWindows:ScalingEffectStop Offset="1" Value="0.2"/> </igWindows:ScalingEffectStopCollection> </igWindows:CarouselViewSettings.ScalingEffectStops>
</igWindows:CarouselViewSettings> </igDP:XamDataCarousel.ViewSettings> <igDP:XamDataCarousel.FieldSettings> <igDP:FieldSettings AllowEdit="False" AllowCellVirtualization="False" CellClickAction="SelectCell" LabelClickAction="SelectField" LabelTextAlignment="Center" LabelTextTrimming="None" LabelTextWrapping="Wrap" AllowRecordFiltering="False" AllowResize="True" AllowHiding="Always" AllowLabelVirtualization="False" AllowSummaries="False" CellContentAlignment="ValueOnly" /> </igDP:XamDataCarousel.FieldSettings> <igDP:XamDataCarousel.FieldLayoutSettings> <igDP:FieldLayoutSettings AutoGenerateFields="True" AllowFieldMoving="No" AllowRecordFixing="No" AllowClipboardOperations="None" SelectionTypeCell="Single" AddNewRecordLocation="Default" AllowAddNew="True" AutoArrangeCells="LeftToRight" AutoFitMode="Always" LabelLocation="Hidden" HeaderPrefixAreaDisplayMode="None" ExpansionIndicatorDisplayMode="Never" FixedFieldUIType="None" FixedRecordUIType="Button" /> </igDP:XamDataCarousel.FieldLayoutSettings> </igDP:XamDataCarousel>
if (e.TouchDevice != null && (productCarousel != null && e.TouchDevice.Captured == productCarousel
var lp = e.TouchDevice.GetTouchPoint(this).Position.X - pointFromLeft.X
var tp = e.TouchDevice.GetTouchPoint(this).Position.Y - pointFromLeft.Y
if (lp <
0)
if (productCarousel != null) productCarousel.ExecuteCommand(DataPresenterCommands.CellPrevious
//productCarousel.ExecuteCommand(DataPresenterCommands.CellLeft);
//productCarousel.ExecuteCommand(DataPresenterCommands.RecordPrevious);
else
//if (productCarousel != null)
// productCarousel.ExecuteCommand(XamCarouselPanelCommands.NavigateToNextItem);
if (productCarousel != null) productCarousel.ExecuteCommand(DataPresenterCommands.CellNext
//productCarousel.ExecuteCommand(DataPresenterCommands.CellRight);
e
.Handled = true
Hello Darrell,
I have been reading through your post and I have created a sample application for you, which demonstrates an approach for implementing scrolling on the items in the XamDataCarousel via touch. In order to implement the scrolling I have used the TouchMove event and in its event handler I am getting the XamCarouselPanel that is used in the XamDataCarousel and using the ExecuteCommnad method I am executing the NavigateToNextItem and NavigateToPreviousItem commands in order to navigate through its items.
Please let me know if you need any further assistance on the matter.
Sincerely,
Krasimir
Developer Support Engineer
www.infragistics.com/support
