920
XamPivotGrid not showing values
I created a project that contains an XamPivotGrid that shows values coming from an xml. All worked fine. But when i put this Grid inside a popup and called this popup from another project, the grid stopped showing values. Although its ((FlatDataSource)this.pivotGrid.DataSource).ItemsSource is populated correctly. All i get now is a Grid that has "Drop Row Fields Here" and "Drop Data Items Here".
Can you please help on how should i fix this?
The button that calls the popup has the code below:
avgPopup.preview((DateTime)this.datepicker1.Tag, (DateTime)this.datepicker2.Tag);
avgPopup.Show();
and in the preview of the popup i call the function that gets the values from the xml and gives it to the Pivot Grid's Itemsource.
When debugging, the grid doesn't enter its CellControlAttached function anymore.
Please advise,
Nazha
