So far, we have been using xamDataGrid. Now moving to xamGrid. Need your help we we apply grouping. Problem we are facing is that header rows are being repeated in each grouping node.
Basically, what I am looking for is similar API, we get in xamDataGrid->Header Placement in GroupBy.
Thanks in advance,
Ravish
Currently this feature is into 13.1 backlog, which means that it should be implemented in the first version release that we will ship in 2013.
Hope this helps you.
+1 vote from me too please
Hello Drew,
I have created a support ticket on your behalf: CAS-82203-NGFFMS and I also logged a separate feature request for you: FR13944. If you would like to follow up on your feature request at a later point, you may contact Developer Support management via email. Please include the reference number of your feature request in the subject and body of your email message. You can reach Developer Support management through the following email address: dsmanager@infragistics.com
Thank you for your request.
Ideally I want something that would look like this where the column headers stay on top, the summaries are displayed in the group by headers and lined up withe the column headers. I found this in winforms grid but not sure it can be done for wpf xamGrid.
+1 vot for adding that feature.
I really would like to see that feature too. Its critical and seems to be supported by most toolkits.
Drew
