920
Filtering and XamPivotGrids
In your samples Filtering, you are using IFilterViewModel to filter the data according to what the user chooses as months.
I tried it and it worked fine with my grid that has the following format which is Brands vs Dates data.
this.Rows = XmlaDataSource.GenerateInitialItems("[Brands].[Brands]");
this.Columns = XmlaDataSource.GenerateInitialItems("[Date].[Date]");
this.Measures = XmlaDataSource.GenerateInitialItems("msvalue");
However, i have another grid that has the following info:
this.Measures = XmlaDataSource.GenerateInitialItems("msvalue,  msvolume");
with no columns and i would like to filter both measures according to what the user chooses in a drop down. but i can't use the IFilterViewModel because it is a IMeasureViewModel. and i didnt know how to go on from there. can you please help?
Below is the code used for filtering using the IFilterViewModel.
private void FilterDates(DateTime beginning, DateTime ending)
            //Run filtering in background process in order to not hang the main UI of your app
            BackgroundWorker worker = new BackgroundWorker();
            worker.DoWork += WorkerDoWork;
            worker.RunWorkerCompleted += (s, e) =>
                bool allUnchecked = true;
                IFilterViewModel fvm = FindDateViewModel((DataSourceBase)this.pivotGrid.DataSource);
                foreach(IFilterMember filterMember in fvm.FilterMembers)
                    if (filterMember.IsSelected != false)
                        allUnchecked = false;
                        break;
                if (allUnchecked)
                    MessageBox.Show("There is no data for the last " + (this.monthsToFilter.SelectedItem as ComboBoxItem).Content.ToString() + " months");
                else
                    this.pivotGrid.DataSource.RefreshGrid();
                    this.isBusyIndicator.Visibility = Visibility.Collapsed;
            this.isBusyIndicator.Visibility = Visibility.Visible;
            worker.RunWorkerAsync(new WorkerArguments()
                DataSource = this.pivotGrid.DataSource as DataSourceBase,
                Beginning = beginning,
                Ending = ending
        void WorkerDoWork(object sender, DoWorkEventArgs e)
            WorkerArguments args = e.Argument as WorkerArguments;
            if (args == null)
                return;
            //Find the Date view model or if not found create it in the Filters area
            IFilterViewModel fvm = FindDateViewModel(args.DataSource) ?? CreateViewModel(args.DataSource);
            if (fvm == null) return;
            //Manual reset event will be used to wait for the members to load
            //when they are expanded or selected
            fvm.LoadFilterMembersCompleted += (sender1, e1) => _manualResetEvent.Set();
            if (fvm.FilterMembers != null)
                foreach (IFilterMember member in fvm.FilterMembers)
                    //Recursively go through all members that need to be interacted with
                    DrillIn(member, args);
            e.Result = fvm;
        private IFilterViewModel FindDateViewModel(DataSourceBase dataSource)
            for (int i = 0; i < dataSource.Filters.Count; i++)
                if (((IFilterViewModel)dataSource.Filters[i]).Caption == "Date")
                    return dataSource.Filters[i] as IFilterViewModel;
            for (int i = 0; i < dataSource.Rows.Count; i++)
                if (((IFilterViewModel)dataSource.Rows[i]).Caption == "Date")
                    return dataSource.Rows[i] as IFilterViewModel;
            for (int i = 0; i < dataSource.Columns.Count; i++)
                if (((IFilterViewModel)dataSource.Columns[i]).Caption == "Date")
                    return dataSource.Columns[i] as IFilterViewModel;
            return null;
        private IFilterViewModel CreateViewModel(DataSourceBase dataSource)
            foreach (IDimension dim in dataSource.Cube.Dimensions)
                foreach (IHierarchy hierarchy in dim.Hierarchies)
                    if (hierarchy.UniqueName == "[Date].[Date]")
                        IFilterViewModel fvm = dataSource.CreateFilterViewModel(hierarchy);
                        this.pivotGrid.Dispatcher.BeginInvoke(
                            () => this.pivotGrid.DataSource.Filters.Add(fvm)
                        return fvm;
            return null;
        private void DrillIn(IFilterMember filterMember, WorkerArguments args)
            _manualResetEvent = new ManualResetEvent(false);
            //Expand all levels to the individual date level
            //and then compare if each date is between the start and end date.
            //If it is select it, otherwise disselect it.
            if (filterMember.Member.LevelName == "Dates")
                if (
                    (DateTime.Parse(filterMember.Member.Caption).CompareTo(args.Beginning) >= 0) &&
                    (DateTime.Parse(filterMember.Member.Caption).CompareTo(args.Ending) < 0)
                    this.Dispatcher.BeginInvoke(() => filterMember.FilterSource.IsSelected = true);
                else
                    this.Dispatcher.BeginInvoke(() => filterMember.FilterSource.IsSelected = false);
                return;
            else
                if (!filterMember.IsExpanded)
                    this.Dispatcher.BeginInvoke(() => filterMember.IsExpanded = true);
                    _manualResetEvent.WaitOne();
            for (int i = 0; i < filterMember.FilterMembers.Count; i++)
                DrillIn(filterMember.FilterMembers[i], args);
