875
Does anyone know how to make Keyboard shortcuts actually work?
OK, here's a sample project.  Someone please answer:
If you right click inside the Save button and click Save on the context menu it works.  How to get the shortcut (Ctrl+S) to do the same????????????????????????
example.zip
  • 138253
    I am just checking if you got this worked out or you still require any assistance or clarification on the matter.
  • 138253
    Suggested Answer
    Thank you for your post. I have been looking into it and the sample project you have provided and I modified it, so now it works as you want. Basically I create an instance of your CommandRefference class and bound its Command Property to the save command because the KeyBinding’s Command Property isn’t a Dependency Property and cannot be bound. Also here you can read more about MVVM Commands:
    http://joyfulwpf.blogspot.com/2009/05/mvvm-commandreference-and-keybinding.html
    Please let me know if this helps you or you need further clarification s on this matter.
    SAMPLE.MVVM.zip
