85
Windows task bar application icon has shrunk - XamRibbonWindow
I am using the following Infragistics dlls - InfragisticsWPF4.Ribbon.v11.1 and InfragisticsWPF4.v11.1
Whn i run this application the task bar icon has got shrunk and its origianl size defined it as 32x32 dimension.
Note:- The same application working perfectly in the older version.
Here i am pasting the XAML code
<igRibbon:XamRibbonWindow x:Class="WpfApplication1.MainWindow"
        xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
        xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml"
        xmlns:local="clr-namespace:WpfApplication1"
        xmlns:igRibbon="http://infragistics.com/Ribbon"
        Title="MainWindow" Height="350" Width="525"
        Icon="{Binding Source={x:Static local:MainWindow.MainMenuIconSource}}">
    <igRibbon:RibbonWindowContentHost>
        <igRibbon:RibbonWindowContentHost.Ribbon>
            <igRibbon:XamRibbon
                x:Name="_ribbon"
    Theme="Office2k7Black">
                <igRibbon:XamRibbon.ApplicationMenu>
                    <igRibbon:ApplicationMenu x:Name="_applicationMenu" Image="{Binding Source={x:Static local:MainWindow.MainMenuIconSource}}"/>
                 </igRibbon:XamRibbon.ApplicationMenu>
            </igRibbon:XamRibbon>
        </igRibbon:RibbonWindowContentHost.Ribbon>
    </igRibbon:RibbonWindowContentHost>
</igRibbon:XamRibbonWindow>
Here i am pasting the code behind:
using System;
using Infragistics.Windows.Ribbon;
namespace WpfApplication1
    /// <summary>
    /// Interaction logic for MainWindow.xaml
    /// </summary>
    public partial class MainWindow : XamRibbonWindow
        private static Uri _mainMenuIconSource = new Uri(@"C:\Documents and Settings\WpfApplication1\Resources\Q circle 32.png");
        public MainWindow()
            InitializeComponent();
        public static Uri MainMenuIconSource
            get { return _mainMenuIconSource; }
 So please help me and do the needful.
Thanks in advance
Shibu Mathew
  • 138253
    Hello Shibu,
  • 138253
    Hello Shibu,
    Thank you for your post. I have been looking into it and the code you have provided and it seems like everything works ok on my side, so if this is still an issue for you, could you please send me an isolated sample project, where this is reproduced, so I can investigate it further for you. Also could you provide me with the full version of your Infragistics DLLs(e.g. 11.1.20111.2113).
